minkstole
- Sep 28, 2010
Hello,
I am hoping someone can help me with an issue I'm having with the line-out connection from my 2nd gen iPod Nano.
I will soon be buying my first pair of audiophile grade headphones as an upgrade from my current pair and have spent hours and hours researching which ones to buy. I will also be buying a headphone amp when I have more money further down the line but for now I will be using my old Technics SUV-500M2 stereo amp to drive the headphones.
My problem is: I don't want to use the headphone-out from the iPod to connect it to the amp and would rather use the line-out. I bought a new Apple line-out dock to plug the iPod into and have a 3.5" to RCA cable to connect the dock to the amp. However the volume level is rather quiet and I have to turn the volume on the amp up much further to get a reasonable listening level when using the iPod than when I am using my CD player through the amp. When using the CD player the amp has sufficient power to easily drive the headphones to a very very loud level. Not so with the iPod.
Also, when using the line-out from the dock the volume is only very marginally louder than when I connect my iPod directly to the amp through the headphone-out via the 3.5" to RCA cable.
Also, when I plug my headphones directly into the iPod headphone-out they again can be driven to a very acceptable volume. However, as a lot of the headphones I am looking at buying require an amp I would really like to get this issue sorted.
So....not really sure where I am going wrong.
Any suggestions would be very much appreciated!
Thanks
Thanks
