Help with installing ASIO plugin for Foobar2000
Aug 11, 2005 at 3:54 AM Thread Starter Post #1 of 3
sirnice
I'm getting an error after I copy the foo_output_asio(dll).dll to the component folder in the foobar2000 directory. When I open Foobar2000 it says unable to load the plugin.
I download the dll from this place. The file I download doesn't have the extension .dll
Is the file zipped. I try changing the extensino to .dll but still getting the error.
Aug 11, 2005 at 6:08 AM Post #2 of 3
I think that file (based on the .7z extension) is compressed with a program called 7-zip, which is like Winzip but provides slightly better compression. You can download 7-zip here:
http://www.7-zip.org/
Aug 11, 2005 at 6:22 AM Post #3 of 3
That was easy. Thanks
it worked
