Drewpy
- Mar 17, 2005
Picked up the card after a number of weeks lurking here while trying to decide what to replace my dead Audigy with. I'm very pleased with the card so far. Haven't had a chance to check out the recording quality yet, but that will come in time.
After searching to forums I came up with: http://www6.head-fi.org/forums/showt...ght=0404+guide
but the link is dead, so as much as I hate to start another thread about what seems to be a well asked topic, I can't find the answer by searching. Perhaps this will also prompt the author to update his link
Anyways, on to my problem: I cannot get ASIO working in Foobar.
ASIO works no prob if I use the onboard Soundstorm Audio of my mobo. Kernel Streaming, Direct Sound, and waveOut all work through the E-MU.
Is the message that pops up.
INFO (CORE) : opening file for playback : INFO (CORE) : location: "file://E:\blah-blah-blah.flac" (0) INFO (foo_output_asio(dll)) : open : 44100 Hz, LINEAR PCM, 16 bits, 2 channels INFO (foo_output_asio(dll)) : ASIO device type [channel 0] : Int32LSB INFO (foo_output_asio(dll)) : ASIO device type [channel 1] : Int32LSB ERROR (foo_output_asio(dll)) : unsupported output data format. |
