Redwoood
- Jul 14, 2001
Hi there!
I have this old PCDP but not its DC adapter.
I do have one of those multi-voltage-el-cheapo wall warts, though.
Its just that none of the plugs fit. No problem (I thought), went to the next RS and got me a fitting plug. Back home, ripped one
of the useless plugs off and soldered the new one onto the cable.
Set the thing to 4.5 volts, and off we go...
Well, not quite. The display of the player turns on and I can select a track, but then when it's about to spin the CD it shuts off.
(Battery operation is still working though)
Well, the display and controls work, so I guess I didn't scew up the soldering. Also voltage seems to be ok, so where's the problem? (I don't own a multimeter)
Is it possible that the wall wart can't provide enough current?
It's rated at 12Vx300mA max.
I don't really understand much of these things so I'm desperately seeking advice from those wiser than me
Thanks
Bye
Redwoood
Thanks
Bye
Redwoood
