MrRockliffe
- Dec 18, 2013
I would like to get some portable headphones as my beyers are too bulky.
I gave some Sennheiser HD201s a listen the other day and quite like the sound.
How do the Pro 700 MK2 compare to the Custom One Pros? Is the M50 a better option, or are the any other good portable headphones for that price?
I listen to mostly bass heavy music.
My Beyerdynamic Custom One Pros have got to go back because the left ear has blown (rattles with bass) and I'd like some headphones that sound similar.
To give you an idea, I really really like the sound of the Sennheiser Momentums.
Clear but not harsh, mostly balanced but slightly leaning towards bass.
Comfort and portability are big factors.
Will be used along with an Xperia Z1
Budget of 200 GBP, but the less I spend the better.
