SorenTheOutcast
Hi there,
long story short, my stock K7xx velour pads (memory foam inside) are filthy, and i was thinking about cleaning them with water and detergent, as seen in this video:
The problem lies in the fact that these pads have a plastic ring GLUED to them, and i was wondering if it would fall off if i submerged the pads in water for a bit.
What do you think? Has anyone else had a similar experience?
