Zenbun
- Jul 8, 2012
So I need new IEMs, I'll use them mainly in the office so isolation is very important but having good value too. They also must have a single DD and a mic or a detachable cable that I could replace with a mic.
Budget is up to 200-300 USD
So after a few days of research, I came up with this list:
Any Etymotic - goes in too deep so no.
Shure SE215 - good isolation but the sound quality might not be worth it.
Sennheiser IE300 - might be sibilant so not good for long listening, which I need.
Final Audio A4000 - same as the previous, might be sibilant so not good for long listening.
MEE audio Pinnacle P1 - it is isolating and has a mic but the quality of these might not be worth the price
MEE audio Pinnacle P2 - I read even more disappointing reviews on these and they're cheaper.
Moondrop Kato - these would have been perfect because they seem to be good all rounders but the only problem with them is that they don't isolate at all, so there's no point in having good quality sound if it's masked by all the noise.
What do you think? is there anything else I should consider?
PS: I listen to many genres so they should perform well with electronic, metal, vocals classic, trap etc
