help with Aria
Jan 18, 2006 at 11:50 PM Thread Starter Post #1 of 8
trivik12
I just received my aria today and I tried to connect it to my laptop. I am not able to connect my headphone to aria
There is no 1/8" to connect. The one listed on the manual is not 1/8" point. What am I doing wrong?
Jan 19, 2006 at 12:00 AM Post #3 of 8
If you need one right away and you live in the U.S. head over to a RadioShack. As redrich2000 mentioned BestBuys, CircuitCity, etc. should have them too. Sennheiser and Grado makes nice ones if you can wait.
Jan 19, 2006 at 12:15 AM Post #5 of 8
I think Radioshack has it for $3. Where do I buy Sennheiser or Grado adapters. Will IEM's work well with those?
Jan 19, 2006 at 12:33 AM Post #6 of 8
Sennheiser and Grado only makes better 1/4 to 1/8 converters, which is the inverse of what you need. 1/4 to 1/8 converters are "trickier" because of potential strain on 1/8 jacks.
As for 1/8 to 1/4 converter, RadioShack's is perfectly fine.
Jan 19, 2006 at 3:05 AM Post #7 of 8
i have a converter that came with sony sa1k and it sounds good. Aria sounds good
