Whitebread
- Sep 16, 2002
Before I say anything, let me state that I am a Mechanical Engineering student with no technical electrical engineering background, so please bare with me.
For a class project, I want to use a Micro Controller to control 4 solenoids based on input from an ADC chip. Maximum total output current from all 24 pins on the micro controller needs to be 50mA or less at 5v so I need an intermediary between the chip and the relay.
*please not that all analog components of this device will have to be NTE components because that is the only type available
I choose an NTE R42 12 volt relay (Data Sheet).
It can support 1.5 amps max carry current which is 50% more than the each individual solenoid will draw.
To control the switch (to switch the switch) side I need to get a transistor that can support the maximum .5 switching current at 12 volts, but I have no idea what to look for because I'm unfamiliar with the terminology and because I don't quite know what kind of transistor I need. The micro controller can out put digital and analog signals at aforementioned voltages and current. Also, 2 solenoids will need to be active at the same time
Can anyone suggest the correct type and polarity of transistor that would be suitable for this application?
