iamsmrt
- Jan 16, 2005
Hey all, I'm in the process of buying a Benchmark DAC-1 from Audiogon. The seller is offering a balanced 1M XLR Wasatch cable (exact model not listed though i believe this cable is aes/ebu http://www.wasatchcableworks.com/AES-EBU.htm ) for $55. Up until recently, I believed that s/pdif and toslink were the only two digital cable standards. Not understanding why the seller would be offering XLR cables with the DAC-1, I've discovered aes/ebu.
From my research today, I believe that aes/ebu is the professional version of s/pdif. Looking at the benchmark dac-1 website http://www.benchmarkmedia.com/digital/dac1/ I've realized that the DAC-1 can use an xlr input, which i'm assuming when an xlr connection is being as a digital cable, this is called aes/ebu?
As well, from the product page of the emu 0404 I've learned that the optical/coaxial inputs and outputs are switchable to aes-ebu. Basically, will this balanced XLR cable (if it is in fact the wasatch aes/ebu cable) be useable and result in better sound quality in my setup than something similar in this price range, ie. around $50. Thanks for reading my long-winded and confusing write-up!
