cbiscuit90
- Aug 24, 2013
Hey guys,
New to head-fi and hi-fi in general, so any help is appreciated! I bought a pair of Beyerdynamic DT990 Pros (250 Ohm). I'm using a Xonar DG (for dolby headphone) as a DAC, and since it didn't have enough power to drive the phones to the desired noise levels, I needed an amp.
Rather than shopping around, my father had an old Yamaha RX-V870 A/V receiver sitting in his garage. I connected the receiver via 3.5mm -> RCA through the front panel audio (connected to the Xonar DG, with the onboard audio disabled).
Everything works fine for the most part, however at some point (either very soon after powering on, or could take hours) the sound in one ear (random) seems to transfer to the other ear, resulting in loud sound in one ear and very quiet sound in the other. Powering the receiver on and off provides a temporary solution. I tried switching outputs from the DG from front panel to rear, and inputs into the receiver, however the problem still arises. I've tried google, but I can't find anything definitive.
Does anyone have any idea what the issue is, and if so, is it repairable or should I move on to buying a new amplifier?
Thanks!
Thanks!
