Oya?
- Mar 31, 2008
I'm getting weird readings on my Millet Hybrid, on the bias for both tubes. Both sides read around 23VDC with the tubes in, I'm feeding the amp 30VDC. Tuning the bias does little to change the readings.
The amp was working fine until very recently. It's in a semi-dismantled state now so I haven't tested if sound comes out fine, but I figured I should fix the bias first anyway before trying any listening.
I've got a Diamond buffer in there which worked 100% the last time I put everything together. I've also swapped in some BUF634s and got the same readings.
Any ideas on where to from here?
EDIT: How can I check to see if the buffers I have are working properly?
Also, I've made tweaks to the board and there was a lot of soldering involved. I've been generally careful but is it possible the trimpots might've fizzled out (if this is even possible?)?
