Keiso
- Mar 8, 2002
As I wrote on a previous thread, I've borrowed a pair of HD600 to compare with my HD590.
Now, my plan was to buy a set of Stax SRS-2020 Basic System II this weekend. But now that I've been listening to the HD 600 for 3 days now, I'm not so sure anymore....
Like I wrote, I'm using the HD600 directly from my SACD player, without a dedicated amp. But already now, I think they kick a lot of @ss!
Buying the Stax set will cost me about twice the price of a pair of HD600. But if I go for the HD600, I will surely upgrade my set later with an amp (most likely with the Sugden Headmaster). Together with a quality amp and maybe the Carda cable, I think the HD600 will be more than a match for the Stax Basic System....
I'm a student with a limited budget right now, but I'm willing to save up and upgrade big time later.
Here's what I think about the Staxs vs. HD600:
STAX:
+ Very comfortable to wear, minimum pressure from the frame.
+ Soothing sound. Music just come out effortlessly. You can listen to them for hours with a smile on your face
+ Including a dedicated amp perfectly matched with the earspeakers.
+ Price more than a pair of HD600, but less than HD600 and a quality amp.
- The pads! The leather will kinda stick to your face after a couple of songs.
- The plastic frame! Not even half as durable as the carbonfiber frame of HD600.
- Lack the bass punch of dynamic headphones (but make it up with deep, tight bass!)
Sennheiser HD600:
+ We all know how good they sound...
+ Look hell lot cooler!
+ Carbonfiber frame can take much more beating!
+ Easily upgradeable/exchangable parts.
- Even after extensive stretching, the pressure from the frame is killing me... I can't wear them for more than half an hour continuously. Need to rest a couple of minutes at least....
- They are not electrostats
So go for Stax or join the already overcrowded gang of HD600 lovers?
Will somebody please give me some advice before my Stax deal runs out on Saturday? Thanks in advance....
STAX:
Sennheiser HD600:
