dsavitsk
MOT: ECP Audio
- Aug 3, 2003
Hammond makes a cute little enclosure, the 1455C802, which is just right for holding a 50mm x 80mm circuit board. However, it is very thin (23mm outside), so a board with any components that stick up more than about 15mm won't fit. This, sadly for my purposes, includes Panasonic EJV pots.
So, I am looking for another enclosure that will hold the same size board, but that is slightly thicker allowing slightly taller components. In an ideal world, I'd like another extruded aluminum one like the hammond, but I'd be happy to find a plastic case that would also hold the boards. There are not mounting holes in the board, so being able to slide in like in the hammond, or having some system to hold it in place would be good. Also, there are board mounted connectors on the front and back, so there need to be flat drillable panels on both sides. Ideas?
As a side note, a shorter pot might also work, if there are any good suggestions, and a way to easily obtain them in the U.S., though there are various TO-220 chips that are also too tall, so this is not the best option.
Thanks.
-d
Thanks.
-d
