tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
Looking at Tangent's STEPS article, he lists slo-blo BUSS fuses in everything from 0.1A to 0.5A for the line side of the transformer. However, he doesn't discuss how these ratings are selected, and they don't have a one-to-one correspondence with the various STEPS VA rating selections.
That's question enough with BUSS fuses. However, Polyfuses are even more confusing. They have distinct advantages for constructing DIY walwarts (SOHA, TREAD-in-a-walwart, etc.): small size and no need for replacement. Unfortunately, the specs are confusing. There is a "Hold Current" and a "Trip Current," typically sized at 0.2 & 0.4, 0.4 & 0.8, 0.6 & 1.2, and so on. The "Trip Current" is always twice the "Hold Current."
If you read the literature, "Hold Current" is defined as that current required to maintain a closed circuit. Does that really mean a current less than that will drop out the transformer? In any event, with Trip Current twice as much, I am confused on how to size one.
In our headphone amps for instance, if a Polyfuse is sized for 0.1A (equates to about 500ma @ 24V on the line voltage side of 110V), does that protect the transformer if it doesn't trip until 0.2A? (about 1A @ 24V) If the headphone amp doesn't draw a full 500ma, does that mean the transformer will drop out from too little current on the Polyfuse?
So, how do I size a Polyfuse to "HOLD" the necessary current, but at the same time, "TRIP" before damage takes place, depending on transformer rating?
