Baines93
- Jul 28, 2007
Hi Guys!
I just fitted my on-loan-from-my-dad Creative Sound Blaster Live! I havnt tried earphones yet, but teh only thing i notice with speakers, is that volume is noticabley lower than i normally have it, but it is just as loud, if not louder
I have my speakers plugged in, and could plug my earphones in on the back too, but my pc has 2 3.5mm jacks on the front which i would like to use for earphones.
On the front (opposite to the backplate) there are tons of pins and the cables coming from the 2x 3.55mm jacks are one-pin connectors:
mic power,
mic in,
Left RET,
Right RET,
Right out,
Left out,
Ground x2.
I know i dont connect them onto the side, where the DVD drive and the rest can plug in, but possibly some of the AUDIO_EXT pins are used at the back of the card? I cant find anything in the PDF manual, or on the internet, if anyone can help i would appreciate it!!
Its a few years old, and just on, loan to try, but i imagine i will buy a £25ish Creative soundcard for myself. And if i learn how to wire these jacks up, i wont have a problem next time!
So far i dont have to have the volume set as high, but it sounds just as loud as it did previous to the soundcard, so thats a plus!
I will try it with earphones when i have connected the two front jacks, and hope there is no crackle and hiss, like there was with AC'97 (ASUS) on-board sound!
Savoring the temporary upgrade! Although i doubt there will be much difference between my Zen Vision M and the Soundblaster?
Thanks in advance.
mic power,
mic in,
Left RET,
Right RET,
Right out,
Left out,
Ground x2.
Thanks in advance.
