davidthepark
- Apr 19, 2013
Focus your budget on speakers more so than electronics, as that will give you the best bang for the buck in sound quality. Better to get the best $1500 speakers and a $500 receiver, than the best $1000 speakers and a $1000 amp.
In addition to being a big difficult to drive, Magnepans are considered to be finicky about placement. I think you might do better with the Focal Chorus that were recommended or a pair of these Philharmonitors or Ascend Acoustics Sierra 1s.
If you ever want to expand your setup with additional speakers for watching movies or blu-ray music concerts, then an audio video receiver would be the best choice. Not only for it's ability to power a center and surrounds, but also because of the bass management (if you ever add a sub) and the built in room correction software (I recommend Denon, Marantz or Onkyo for Audyssey room EQ). Then there are additional convenience features like music streaming capability, remote management via android or ios, bluetooth, etc. AVRs are often a better price/performance value than integrated amps because they are the more competitive area of the market. Previous year Denon models tend to go on sale spring/summer as the new models come out, so you can get excellent deals if you are patient.
With apartment living, a sub can often be a problem with neighbors. If you listen to music with deep sub bass (e.g., EDM or hip hop) or plan on using your setup to watch movies, tower speakers could be the way to go to give you extra low bass over bookshelf/monitor size speakers instead of adding a sub.
Finally, forget the Audioengine P4 speakers. There are better choices out there in that budget range (Chane A1rx-c, HSU HB-1, and Ascend CBM-170 SE). The P4's are only popular among people who know the Audioengine brand name and don't know about other options.
This may be a stupid question, but if I get a AV receiver, do I not need any other components such as tube amps or DACs or phono amps for my turntable and MacMini (which will be just used to listen to my music on iTunes library and watch movies through a DVD reader. I will NOT be getting a DVD/blu-ray player)
