Help searching for closed
Dec 30, 2005 at 3:01 AM Thread Starter Post #1 of 8
haibane
Hey, I have a pair of senn HD580s that I enjoy, however I would like something a bit more up beat(not as laid back) and also something closed because I was just on a 11 hour flight and man did it bite using the ipod cans if you can even call them that. Anyhow, here is what I am looking at the AKG K271 or the Beyerdynamic DT250. I lean more towards the AKGs for the very shallow reason of the fact that they look a lot better. Anyhow, any help is appreciated. I currently use home made amp for my headphones also if that helps
Dec 30, 2005 at 2:03 PM Post #4 of 8
Originally Posted by haibane
Alright. So are there any closed Sennheisers that sound similar to the hd580s?
not exactly.. Another option would be the A900s. I think the A900s are going so sound alittle more like the HD580 because of the bass being more present. I can't see you going with a cheaper line with the HD580 sounding so good.
Dec 30, 2005 at 2:13 PM Post #5 of 8
Originally Posted by chrisfromalbany
not exactly.. Another option would be the A900s. I think the A900s are going so sound alittle more like the HD580 because of teh bass being more present. I can't see you going with a cheaper line with the HD580 sounding so good.
I think I have decided not to replace, but instead get a second set so I can use them for studio etc.
Dec 30, 2005 at 3:06 PM Post #6 of 8
HD280s or the A900s
Dec 30, 2005 at 3:52 PM Post #8 of 8
Those a900s are a pretty penny lol
get them used or get A500 or A700.
