rwpritchett
Hello all,
The quality of my headphones has outpaced the quality of my amps and its time for an upgrade. I'm relatively new to the hobby and started with some low level amps. Currently, the main amp I use is the 1st gen Aune T1. My climb up the headphone ladder has left me with the following headphones in my current stable: HiFiMan HE-500, AKG K702-65/AE, AKG K550, Focal Spirit Classic, Yuin PK1, and some others that don't really benefit from amping.
From what I've read, two of those headphones (the HE-500 and K702-65/AE) sound their best with an amp that puts out a lot of current and I think it's time to upgrade the underpowered Aune T1 MK1 which is also used as a DAC for my powered speakers and sub. For budget, I'd like to keep it under $400 unless forum advice leads me to save up more to get what I'm looking for. I listen mostly to FLAC files from the following genres: classic rock, modern rock, blues, acoustic, vocal jazz, classical. I tend to prefer v-shaped sound and I love realistic soundstage.
Must Haves:
Like-to-Haves:
In my research, I've come across the following candidates:
Right off the bat the NFB-15 seems to check all the boxes. My only concerns with that one is it's been EOL'd and long distance customer support in Hong Kong. Perhaps the NFB-11 would be a better choice, but from what I've read the Wolfson NFB-15 DAC has the sound signature I'm looking for over the Sabre in the NFB-11. The Schiit stack has a lot of features I want, but it seems to be a side-grade from the Aune T1. I can't seem to find much information on the Matrix HPA-2 compared to Audio-GD or M/M, but it also has the largest footprint of the three. Then there's the last option... something I've missed in my research? I'd love to get a Woo WA7 Fireflies or Bifrost/Asgard 2 stack, but those are out of my price range. I don't have any local shops to try-and-buy so I'm trusting the forum for advice.
All advice and criticism welcome. Thanks in advance.
Must Haves:
- RCA pre-outs for my powered speakers
- 6.35mm (1/4") jack
- USB, TOSLINK, or Coax input
- Small desktop footprint
- I prefer a DAC/Amp combo due to the size advantage, but open to separate components if stackable or small enough footprint
- For the DAC, I would like minimum 192KHz sample rate
Like-to-Haves:
- Variable pre-out instead of fixed
- Support for 88.2KHz sample rate
- Future upgrade possibilities (i.e. XLR balanced out, DSD support)
- Low output impedance for my easy to drive cans
- Adjustable gain
- Audio-GD NFB-15.32
- Matrix M-Stage HPA-2
- Schiit Magni/Modi Uber Stack, fully upgraded
- A make/model I've overlooked?
