akenkel3
- Jul 5, 2014
So I've been looking into getting an amp for a portable set up using my ipod touch 5th gen and my Sennheiser Momentum, and for when I make my next purchase, the hd 598. As for the amp, I've been looking at the C&C BH2 as I believe it does exactly what I want as a first purchase amp.
Now I've been reading (and correct me if I'm wrong) that you need a LOD to go from the ipod to the amp to bypass the internal amp. However, with the new lightning connector this isn't easily accomplished because of something about not being able to extract the analogue signal. The only LOD from a lightning connector I saw was about $85 which is preposterous in my opinion. I'm only willing to spend about $10 on a cable.
So are there cheap LODs available for the lightning connector? I haven't found one. Or will I have to do a different option of chaining the amps using a 3.5mm jack to 3.5mm jack from the ipod to the amp? Or the other option of lightning -> 30 pin connector-> LOD-> Amp-> Headphones? That seems cumbersome to me...
So all in all which is the best option for me to use an amp with an ipod touch 5th gen? Thanks.
