LarBO
- Jan 17, 2004
I've got a PPA that I bought from a member here some time ago and I've been using it with some HD600 phones. Actually, not using it as much as I'd like for a variety of reasons, one of which was that it was a bit too forward/aggressive for my taste. After reading a bit here I learned that the AD8610s might be giving me too much 'detail' and that the OPA627s might be better. So I got ahold of some OPA627 op-amps and put them in. I prefer the sonics with the OPA627s. However, if I crank the volume up to even 11 o'clock (moderate-to-high listening level for me) there's a distinct distortion that worsens if the volume's increased. It's worse if the bass-boost is on. I don't recall this happening with the AD8610s. The distortion is there, but to a lesser degree at lower volumes.
Can anyone clue me in as to what might be wrong here? Are the OPA627s bad? Could the buffers (12 x HA-5002) be bad? I'm pretty ignorant of this stuff, but can easily swap these things as they're socketed, and can even make a solder joint to be proud of if needed.
I know the PPA wasn't necessarily designed for 'phones like the HD600s, but LOTS of people seem to pair these up without complaint so I figure something must have gone wrong with my amp. The phones are fine when used with other amps/sources.
Thanks in advance for the help/advice.
