Help please....my Sony SA5000s...pad lifted..
Dec 15, 2012 at 4:50 PM Thread Starter Post #1 of 5
jtwn
Not the ear pad :wink: But the pad (or whatever you call it where you terminate the cables on to the driver has lifted on my SA5000s).
I only recently re-cabled these headphones with an old HD600 cable. Well, I feel asleep with them on to wake up a few hours later...with sound only coming out of the left channel. Great...so I resolder them etc...screw the housing back together...still doesn't work. I tried a continuinity test and all appears fine. Could not understand. After the third or so time of resoldering...the pad lifted and ended up being stuck to the cable :frowning2:
See pics -
Is this repairable at all? Whilst I'd like to blame the higher temps needed in lead-free solder world (UK)...it probably half is my dodgy soldering skills :/
Any help would be appreciated. Thanks.
Dec 17, 2012 at 6:20 PM Post #4 of 5
It looks like you have burnt out the trace to the driver's coil... Only thing left to do that i can think off is perhaps trying to lift the whole PCB board and soldering to the free coil leads. I think you need a very fine soldering tip to do that though, to avoid burning the diaphram itself (speculating).
I'd suggest trying to get help in the DIY section, if you didn't already.
