precsmo
- Dec 7, 2006
Hi to all gurus, I'm very keen to try this Taiwanese designed buffers and it was claimed officially that it can replace buf634. But I'm kind of stucked here of how to hook these buffers to my Pimeta? I really hope someone can advice me what I should do. I apologize in advanced if this topic had been posted before, but I've tried to search everywhere, I can't find any. Kindly refer to this buffer schematics and some attached pictures. And these buffers are inexpensive and can be ordered here: http://www.hohodiy.com/index.aspx?act=p&pid=263
well, my question are:
1. it was mentioned that these buffers were designed for dual voltage power supply, and the Pimeta has the virtual dual voltage power supply, so, it should work right?
2. it is about the R11 resistor value in the Pimeta, for now my Pimeta is with 2 stacks buffers for the channel buffers, which mean the R11 value is at 100omh. And how should I distinguish the new value for the NeoMini Buffer.
3. and most importantly, where can i start getting hints of from where to where should I hook this buffers to?
I'm really interested to take the possibility to try these buffers with my Pimeta!
Oh, I've forgotten to mention, the initial kits of this buffer is packaged for 15V~20V power setting, and it can be tweaked for 9V~15V and 20V~24V.
