Chronnoisseur
The TLDR: What's the best setup for HE6se for less than $1k? Best for around $2k?
Fell down a rabbit hole and I need help getting out. I'm looking for a headphone amp/dac that's a good match for my new HE6se headphones. I thought I knew what I wanted to power them but after further research I cant decide. Originally I was going to buy a new Bifrost and Jotunheim from Schiit. Then I read a speaker amp would be better so I was considering the Vidar with a preamp (which dac with this setup?) or possibly a fully loaded Ragnarok. Then I read the schiit stuff might just be hyped up so now I'm considering other options. Eventually I will probably get a FirstWatt J2 since I've heard good things about that amp but I need something in the meantime. How can I make the HE6se sound the best on a headphone amp with around $1-2k to spend?
Amps I was considering:
DACs I was considering are (do I need a balanced dac if I get a balanced amp?)
- Schiit Jotunheim (with Bifrost most likely but was going to get the built in dac to see if I could even hear a difference)
- Schiit Ragnarok fully loaded
- Monolith THX AAA 887
- Monolith Liquid Platinum
- Emotiva BasX A-100
- Vidar (is Aegir worth an extra $100?)
- Schiit multibit dac (bifrost probably)
- Topping D50s or D70
- ADI-2 DAC FS (Can get 1st gen used for ~$800. How does this compare to the bifrost and D50/70? Looks more appealing to me cuz the volume control and eq)
