JTLovesMusic
- Jul 6, 2014
Would like to know how should i set the EQ for this Sony player (i would like to have more bass and a little more treble without muffling the mids help is appreciated, =)
SImple. Just boost 0.4 a bit, maybe even 1 for bass, and boost 6.3 for treble. 16k boost is also recommended. Though I don't recommend boosting more then 2db. Or, you can just bring down 2.5 to cut down the mids a little. Also mess around a little with Clear Bass option. EQ will worsen SQ for a fact(even if barely), but if you want more bass and treble, increase the lower and the upper end of the spectrum.
Is that so, how will a proper EQ worsen SQ?
Well, on most DAPs, the EQs are software EQ, where distortion tends to increase. On a proper hardware EQ, the SQ will remain, but not on a crappy software EQ. Especially ones like "Clear Bass".
then is it better to boost the treble or bass with an external amp
The EQ on your device is most likely rather poor, but probably fine to use, though it may introduce distortion/clipping etc. Consider it a fun feature.
@kimvictor we do agree that properly implemented software EQ doesn't make for worse SQ, right?
