LED's just need a source of power and a ground with the correct reisitor on the + side. I'll try to look at mine later and see if I can find a good point to run a lead from.
Originally Posted by Duc LED's just need a source of power and a ground with the correct reisitor on the + side. I'll try to look at mine later and see if I can find a good point to run a lead from.
thanx! Btw, what is the volatge inside the LD2+? 5V? 12V?
Originally Posted by penguindude Is this the LD2 or the LD2+? I need the LD2. Thanks anyway.
That would be the LD2+. You can tell because of the extra set of RCA's and the EF92's.
Either way, if I'm not mistaken, (which I may be) the inside should be extremely similar. The LD2+ just has the preamp function and different tubes up front. Once again, I'm not sure. It's just a guess.
