Originally Posted by PATB
I currently use iTunes to make another copy of my CD for use in the car. Since I only rip to 320K (for my iPod), the copy is not an exact copy of the original.
Can anyone recommend an easy to use program that will allow me to make a 1:1 copy of a CD without having to rip the CD to iTunes or Windows media player first?
Thansk in advance for any information.
---Pat
Pat
Unless you have 2 disk drives (Like me) you will always have to rip, or otherwise load the CD onto your hard drive in order to turn around and burn a copy.
However, if you go to your iTunes preferences and under the importing tab, change it to AIFF encoder, you will get a full strength non compressed file to make a copy from.
Once you're done burning you can delete the music to save space if you like.
Since I have 2 disc drives, I have been using Roxio's Toast to copy CD's, it's noticeably faster than iTunes and also has the ability to copy enhanced CD's that have non music info on them.
TR
Hang on,
Just re-read your post.
Rip the CD in AIFF FIRST.
Burn your CD, then switch your import preference back to 320K.
Select the music you want at 320K, click the advanced tab and pick "convert selection to 320k".
iTunes will down-convert it for you.
There ya go
