Help on choosing from a selection of headphones
Aug 26, 2013 at 3:10 PM Thread Starter Post #1 of 6
pteixeira
Hi Head-Fi!
I need to buy some headphones as my previous pair (Pioneer SE-M290) got a busted wire that I can't fix and now I can only listen from the left side :|
Previously to these I owned a pair of Creative Fatal1ty gaming set (these were sooooo comfortable!) that lasted me like 4 years (before I trampled the wires with my chair...).
These headphones need to be around-the-ear (over-the-ear ones make me really uncomfortable) and somewhat isolate the sounds from the exterior.
I talked to a few of my friends and read some reviews online, but I found some headphones that I can't really decide from..
I had initially focused on the Sony MDR-V6 since they were reasonably priced (getting them from Amazon UK - I'm in Portugal) and a friend of mine let me try them on and listen to some music on them.
Some friends recommended the MDR-7506, but reviews actually say they are the V6 with a visual revamp.. How accurate is this? There is still a difference in the price (V6 - 49.50GBP; 7506 - 69.99GBP).
Some other friends recommended the Sennheiser HD 215 (59.99GBP) and even the Creative Aurvana Live (52.17GBP).
Also saw some people mentioning the Sennheiser HD 439 and HD 449 but I have no clue how they fare against the others. These I can get locally, but I don't think the prices justify it (449 - 99.99€; 439 - 79.99€)
These headphones would be used almost exclusively in my laptop and desktop as I use a pair of awesome earbuds for my iPod. I would listen to music (electronic and rock, mostly), play games and watch movies (the usual use, I guess...).
Bottom line, I have no clue what to get. Whenever I need to buy anything that costs a little bit, I tend to over research and get extremely confused... They would be purchased most likely from AmazonUK, unless I can get whichever cheaper in another trusted location.
Purchasing a small amp/dac is not in my future list of purchases, if that's any help..
Aug 29, 2013 at 8:41 AM Post #2 of 6
Hi Head-Fi!
7506 is basically remade V6. Sounds identical. Anyways, what kind of sound signature are you looking for?
Aug 30, 2013 at 10:52 AM Post #4 of 6
Thank you for the replies!
I was looking for a warm sound signature (if I read correctly, a bit heavier on bass and voices?) since I kind of got used to these from the other headphones I had and I find it quite comforting (if that makes any sense..).
Aug 31, 2013 at 1:20 AM Post #6 of 6
The HD439 have a rolled off highs (treble). Other than that, it perfectly suit your needs. At the moment, can't think of any better alternative yet
Billson :)
