Help needed to upgrade the capacitor in OTL tube amp
Feb 26, 2013 at 10:51 PM Post #107 of 113
telecaster
Who's the gentleman in suit? My guess the La Figaro boss himself?
Wow! 339 Reference, really nice!!
I wish to have the Audio Precision (AP) analyzer even for one day, unfortunately  the kind of measurement apparatus is beyond my reach.
The (Ap) graphs already shows how good the 339 Reference is, really impressive!
The frequency response at low range band is very interesting it's slight boost the upper bass when the load is applied I had similar with my DK339. The mid and high range band is PERFECT -0.4dB on 20kHz! It's probably merit of the new adaptation of input stage (new input tube) may I ask what tubes are they?
The spectrum graph show that mains hum is very low -91bB at 50 Hz almost not audible, THD with the highest 2nd harmonic [dB] -102 and the 3,4,5,6,7,8,9 harmonic below [dB] -110! amazing.
I really appreciate it. You put a lot of thought and effort into that mod. Great work!
Hey Wall-E, I believe they are EF86 ;p
Apr 10, 2013 at 1:02 PM Post #108 of 113
StalkerAssassin
Hello people.
How you these capacitors Jantzen Cross Cap as output separation? I want to use them for DarkVoice 336SE. Will there be enough 100uF for channel?
Apr 10, 2013 at 4:39 PM Post #109 of 113
WALL-E
Hello people.
I don't remember now, what is the value of output coupling cap in DV336se? What headphones will be plugged into it?
Apr 10, 2013 at 4:47 PM Post #110 of 113
StalkerAssassin
In stock Darkvoice 336SE - 20uF per channel, La Figaro 336C - 40uF per channel. But I will only use the circuit from 336SE, I will do all of the new in large chassis.
Sennheiser HD 650.
F = 1/(2 * pi * C * R)
F= 1 / (2 * 3.14 * 0.0001 * 300) = 5.3 (Hz) This means that up to 5 Hz, frequency response is linear, with no recession on the low frequency?
Apr 10, 2013 at 5:16 PM Post #111 of 113
WALL-E
Sennheiser HD 650.
Well bigger enclosure, it is understood so u have a lot space to put good but large film caps, the mkp jantzen will do this job pretty well, with 100uf and 300 ohm headphones you'll get -3bB at 5Hz and the optimal frequency response is about 53Hz It means the roll off start from 53Hz to reach the point at 5Hz, but if u really want flat frequency response 20Hz at 0dB u need 265uF cap
This is the frequency response graph which my measurements, the white plot show the 130uf cap with the 300 ohm load and the yellow & blue 265uf on to 300 ohm, so as you see only with the bigger cap the FR is flat up to 20Hz
Apr 12, 2013 at 11:43 AM Post #112 of 113
kramer5150
Don't forget too the impedance (or resistance... I forget which) of the power tubes.  It gets added to the load impedance of the headphone in the high-pass cutoff frequency equation.
So in a TS-5998, dual triode, paralleled output configuration its ~70ohm + ~70ohm.  together in parallel result in 35ohms... that gets added in series to the headphone load impedance.  32ohm grado thus is really 32 + 35 total in the f-Hz calcs.
Apr 13, 2013 at 3:55 PM Post #113 of 113
WALL-E
good point Kramer!  have a look on FR graph, it is good example, the plots red and purple tung-sol 7236(mu-4.8) higher output impedance vs TS5998(mu-5.4) slightly lower, 265uf output coupling cap into 50 ohm dummy load resistor. We can see how the tube impedance affect the FR, small difference because 7236/5998 are similar but there are.
I have another good example even more interesting, this is FR graph(ARTA software) taken out from my current setup LF339, tung-sol 5998, gec1067 and 325uf output coupling capacitors.
5998, 325uf 5% tolerance on to 33 ohm dummy load, the -3dB point is about 9.5Hz, ok let's mats, for the perfect model high-pass cut-off frequency for 325uf and 33ohm load will be 14.84Hz at -3dB so we have 14.84 (calculated) - 9.5 (measured)  = 5.34
5.34Hz is the tube impedance effect on frequency  response.
Ok, let’s see for an amp impedance, to get the 9.5Hz at -3bB with the 325uf cap we will need load about 51.5 ohm.
51.5(calculated) - 33(measured) = 18.5
Does this mean the 18.5 ohm is a output impedance? hmmm...slightly too low for a amp with 5998 as a output tube. It can be concluded, that impedance has a partial (some) influence on the high-pass cut-off frequency equation IMO.
DV337 & LF339 are cathode follower amplifiers, in this case, I think the output impedance for TS-5998 will be a little bit different.
A cathode follower never has a voltage gain more than 1, Vin = Vout, what it does offer is current gain, that is why it is used to drive hungry current cans.
The output from the CF is taken from the cathode, which has an impedance of approximately 1/gm(higher gm a lower output impedance) the transconductance of the tube, is also in parallel with the cathode resistor which primarily sets the idle current through the tube.
Knowing that the (Zo) formula for a cathode follower should be, Zo = rp/(mu+1), where (rp) is the plate resistance, (mu) is the amplification factor.
TS-5998:
               - (rp) 350 ohm approx
               - (mu) 5.4 some datasheets gives 5.5
350/(5.4 +1) =54.68 / 2 (because parallel triode section) = 27.34 ohm.
Does this mean the 27.34 ohm is a output impedance? hmmm...close enough, but not exactly. Data sheet shows only limited information, what will be the plate resistance for example 140V?, the (mu),(gm) can varies depending on the current flow, the 5998 wit max plate current amplification factors can rise to 6.2 which has a large impact on the final impedance of amplifier.
Only by measuring the impedance on working amp(driving the load) can give reliable and correct number of output amp impedance!
