v1ndictiv3
- Sep 30, 2013
Hey there.
A while ago the sound from the right driver of my AD700's completely cut out. It wasn't until recently that I decided to try and fix them but I've run into some issues: I cut off the old jack and re-soldered the wires onto a new one and I'm getting sound from both drivers, however I get almost no vocals from the right. The right predominantly plays instruments and background music and the vocals it does play sounds very faint and hollow. Also, I believe the volume coming from the right driver is lower than the left. I tried opening up the headphones to check connections and from everything I can see no soldering points have come undone and there doesn't seem to be any points where a wire might be touching another causing a short. I decided to play around with the wire connections to the aux jack and noticed that if I touched the left cable to its prong along with the ground, both drivers play at equal volume and there's no distortion to sound at all... I just then lose my stereo imaging. This leads me to believe the issue is with the cable somewhere and not the driver. I'm considering re-cabling them with this: http://www.redco.com/Mogami-W2893.html. I'd like to know if anyone has any input or any further tests I can do to make sure it's not a driver issues (so i don't waste time and money on cabling). Also, if I did decide to re-cable should I change the wires that connect the right driver to the left? Any and all suggestions/help is greatly appreciated.
Thanks,
C
Thanks,
C
