tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
Lift the battery partway out of the holder so that only one terminal is making contact. Put the meter inline with the other terminal, completing the circuit. If it's an analog meter, polarity matters -- if you don't get the needle to move in one orientation when the power is on, swap the probes.
As for the input resistance issue, you don't need the mini-to-mini now that the amp is out of the case. You can measure directly at the solder joints on the input jacks. Trace the wires to the board to find out which one goes to IG, and that will be your ground. The other two will be left and right input.
