diditmyself
- May 22, 2009
Originally Posted by rds /img/forum/go_quote.gif Are you sure the part after U1 is right? It makes no sense to parallel R8 and R9 or C7 and C8... |
Originally Posted by hopeless /img/forum/go_quote.gif Probably it was chosen for a certain effect on sound. |
BTW a 10 nF capacitive load for the opamp (since the isolating resistor is very small, 10 ohm) makes for heavy loading of the DAC opamp - which may explain why people prefer the discrete opamps for the Zero. |
Originally Posted by cobaltmute /img/forum/go_quote.gif C1 C5 C6 and C7 are all the same position (not value) as on the AD1852 datasheet. |
3RD ORDER LP BESSEL FILTER CORNER FREQUENCY: 75kHz GROUP DELAY: ~3.5ms |
Originally Posted by diditmyself /img/forum/go_quote.gif 10nF is a tough game for any amp. Why is it there? |
Originally Posted by diditmyself /img/forum/go_quote.gif LOL, they hear the sound of a 22 pF cap when there's one 1000 times bigger cap in parallel with it! |
Originally Posted by cobaltmute /img/forum/go_quote.gif From what I have read, most Sigma-Delta DACs need a following low pass filter as they create a lot of high frequency noise |
