Rick Hunter
- Oct 24, 2006
My current setup is
320 kbps cbr AAC or ALAC --> 2nd gen. 8GB Ipod Nano --> Alo bling bling dock --> Little Dot Micro+ --> HD595
I listen mostly to rock & pop & similar: Keane-Radiohead-Pink Floyd-Aerosmith-Coldplay-Shins-Nirvana-Smiths-Pearl Jam-Queen-Springsteen-Lou Reed-Bryan Adams-Dire Straits-etc...
I quite like my setup at the moment but sometimes i feel the HD595 on some tracks lacks a bit of punch in the bass department, especially in kick drums.
I will get in a few days (monday or tuesday) a ALO Jumbo Cryo Dock and a RSA "M" Hornet
Do you think the new IC and the new amp (The Hornet is supposedly punchier in the bass than the LDM+) will give me that little extra bass punch & oomph I'm seeking or should I consider buying a new pair of cans?
If this is the case what cans would you recommend? I would like a can with a sound signature similar to the 595 only a bit punchier/fatter in the bass (keep in mind I like contolled and tight bass response, i hate boominess or loose bass)
Would the HD600 be a good choice? Or should I go for the 650? (I'm afraid I might find the 650 a little too bassy for my taste)
Thanks for any reply, guys.
