help me replace my SR80s pls...
Aug 24, 2007 at 8:24 PM Thread Starter Post #1 of 33
andres
I´ve been using the Grado SR80s for about 6 months already. I use them 8 hours a day, to listen music from my hp laptop (which has a really good sound card).
Things I like from these phones:
1. Good nice deep bass
2. Wide soundstage
3. very detailed mids and highs.
So basically soundwise, they are perefect for me. However, there is something really annoying about them: they are UNCOMFORTABLE. I can wear them for 1 maybe 2 hours, but anything beyond that is unbearable.
I listen to my music in a noise and very active work environment. With an open back design like the Grados, I hear ALL the background noise and cannot fully concentrate on the music, so i have to turn up the volume on my phones. And when I do this, my coworkers complain that they can hear my music.
I have issues with in ear monitors, so they are out of the question. Please do not even mention them as options.
My budget is strictly under $300.
Please help me...
Aug 24, 2007 at 11:37 PM Post #3 of 33
judas391
"soundstage on sr80" ... that's a first
Aug 24, 2007 at 11:44 PM Post #4 of 33
epaludo
I was shocked also ...
Imagine when he listen a K701 then ...
Aug 25, 2007 at 1:08 AM Post #5 of 33
BrookR1
I would honestly look into a used pair of Ultrasones. The DT770s are just bass monsters...and the bass covers everything else up. The Ultrasones (at least the ones I own) have good highs and punchy bass.
Aug 25, 2007 at 1:43 AM Post #6 of 33
1Time
I first thought a modded Ultrasone Proline 650 would be the perfect fit for the OP. However, I then thought there's no way I'd want to wear a Proline 650 for 8 hours straight, let alone almost daily for that long. So I changed my mind and suggested the DT770. I suspect the OP's integrated sound card would have a hard time driving the DT770's bass to overpowering levels. No better closed cans for the OP's needs come to my mind.
Aug 25, 2007 at 2:28 AM Post #7 of 33
BrookR1
I'm listening to my DT770s right now...even modded, they're nothing but boom boom cans. There's definitely less of a sonic jump from the SR-80s to the Ultrasones.
Aug 25, 2007 at 3:08 AM Post #8 of 33
1Time
BrookR1,
That's pretty much why the Proline 650 first came to my mind. Still wouldn't want to wear them though for 8 hours straight. Have you considered the latest mod for the Proline 650 in this thread?
Aug 25, 2007 at 3:34 AM Post #9 of 33
blackinches
I came here to make the same complaint, except regarding my SR-60s + bowls.
My budget is under $200. How are the Sennheiser HD-595s?
Aug 25, 2007 at 3:59 AM Post #10 of 33
spurlints
Since you say the sound is not the problem, have you considered using the comfies from Grado instead of the bowls (which I assume you're using)? You can get them for ~ $10; they're a lot more comfortable than the bowls, which I'm using right now (they're killing my ears...lol)
Aug 25, 2007 at 4:28 AM Post #11 of 33
kamal007
try flat pads, senn hd414, reversed hd414 pads, c-pads..
Aug 25, 2007 at 4:37 AM Post #12 of 33
blackinches
I'll consider that. A friend gave me these SR60s. He'd left them in a closet for ~5 years and the original pads were deteriorating. The foam was hard and crumbly and falling apart more each time I touched it, so I bought these bowls based on their supposedly better sound quality. I would've gone with the comfies if I'd known the cans were unwearable after 1-2 hours...
Will these sound much worse?
Aug 25, 2007 at 9:31 AM Post #13 of 33
Bootleg
Ultrasone PROline 750's or Denon D2000's
Aug 25, 2007 at 1:50 PM Post #14 of 33
Moocher
What about the Audio Technica A700 or A900? Closed, supposed to be very comfortable, decent sounding.
Mooch
Aug 25, 2007 at 2:03 PM Post #15 of 33
epaludo
I seems that it may be more comfortable than bowls. A search could return you better results though ...
