Help me re-cable my KSC75...
Jul 2, 2007 at 7:06 PM Post #3 of 47
Jul 2, 2007 at 10:38 PM Post #5 of 47
Originally Posted by grndslm /img/forum/go_quote.gif
Actually... I need to know how heavy/thick that Mini Star Quad cable is for portable use. I will be using the headband, so it prolly won't be as bad as with ear clips.
If it's pretty thick, tho... I might as well just get a straight jack, I'm guessing...
IDEAS??
Buy some 30 AWG solid core wire and braid it. For clip-ons, you really want something lightweight.
Jul 3, 2007 at 1:37 AM Post #6 of 47
he said he's using a headband, but yeah i still think you should go for something lighter than the starquad.
Jul 3, 2007 at 7:38 AM Post #8 of 47
I re-cabled my KSC75's with some braided SPC wire, Silver Plated Copper, (it's AWG escapes me, I got it from FallenAngel).
This braided SPC wire is some what stiff and microphonics like mad!
I am going to get some Mogami 2799 Neglex Mini Quad cable and see how it comes out. It's only 0.126" OD (3.2mm)
Or I might use some Belden BL-82723 cable
Jul 3, 2007 at 10:33 AM Post #9 of 47
That Mogami Neglex looks like the shiznit, Joshatdot! I'd definitely be willing to at least go in half with someone else because I don't think I'll need all 80ft required to make the purchase.
I assume I could use something like this: http://cgi.ebay.com/50-26-AWG-Silver...QQcmdZViewItem
But it'd prolly be A LOT easier to use the quad cables, eh??
Jul 3, 2007 at 3:52 PM Post #11 of 47
Looser braid, thinner wire, 3/16" multifilament all help. For DIY cables, if you give the wires more room, they'll be less microphonic.
Jul 3, 2007 at 3:56 PM Post #12 of 47
And what right-angle jack should I pick:
Neutrik NTP3RC-B OR Switchcraft 35HDRANAU???
First off, www.audioadapter.com has the best prices for Switchcraft products I've seen.
Here's the low down. Neutrik mini's have a hard gold plating, unlike the Switchcraft mini's soft gold plating, so it won't wear out. On the other hand, Switchcraft mini's are much easier to solder and make a tight connection with all mini jacks, something the Neutrik mini's can struggle with since the acutal plug is slim.
Jul 3, 2007 at 4:22 PM Post #13 of 47
I looked there, but markertek was still cheaper...
I've never soldered anything before, but I think I'd still rather have the Neutrik's harder plating than easier access for soldering.
Jul 3, 2007 at 9:00 PM Post #15 of 47
NOWWW....
What about TechFlex??
Will I need it with the quad cable types? And if so, which one is the most flexible, and where do I buy it??
I am interested in some TechFlex also. I think for the 2799 cable a 1/8" should be fine, no?
