Barndoor
Hi Guys,
I managed to break my colorfly C4 whilst trying to change the battery. The battery had some glue on it that damaged a component when I removed it.
In the just right of the middle there is an empty plastic circle.
This was the same as the 3 black circles near the bottom with 100 on them.
I have no experience but am guessing this is some kind of resister?
Any advice on what it is so that I can get a replacement would be appreciated.
I've successfully replaced the battery, but the device won't turn on. If I bypass this component with tweezers on each terminal then it does boot, so I'm fairly certain that this is the issue.
Would appreciate any advice.
Thanks
Thanks
