DCofficehack
- Dec 27, 2009
I spend many hour each day with both my Beyerdynamic DT770s and my DT880s. The closed DT770s are for the office; the open 880s are for home. (FYI the 770s are 32 Ohms run straight off my MacBook Pro, the 880s are 600 Ohms, run via a Schiit Magni 2. Same Macintosh. Same music.
It turns out that I prefer listening to the 770s, and I'm trying to figure out what lessons I should draw regarding the sound I like and the kind of cans I prefer. Mainly, I find the 770s are more engaging, and I sense that with the 880s I have to turn up the volume to be similarly engaged and also to appreciate a lot of what it can do. I oddly sense that the 880s are better, but I have to turn it up more than I should, and that I like the 770s more anyway.
One theory is that it's the sound signature, but it's not clear to me what the difference is. I think the 880s are more flat...does this mean I like a V? Also, the clamp on the 770s is better. I bought the 880s used and they are loose. All this adds up to better sound isolation and a feeling of more direct sound, while the 880s sound more distant. Last night I was experimenting with holding the drivers closer to my ears. Not sure it made a difference.
Might my 880s simply need a more powerful amp?
Thoughts?
Thoughts?
