ProFingerSk8er
- Feb 15, 2003
yupp, that itch for an upgrade again.
i have heard many said that W100 sounds good with tubes, i dont know if i can ignore those posts
any suggestion on DIY tube amps? im intersted in something a level (or two) higher then PIMETA, and goes well with ATH-W series.
i will also be upgrading my source soon, i just want to build some higher-level tube amps, i have seen some very intersting kits, but the search function isnt working currently, im having trouble finding those links.
right now i am more intersted in kits then completely scratch built, mostly because i know 0 about tubes and picking out parts takes a looooooong time. as for price range, i havnt decide yet, but any suggestion under $380 would be great.
thanks!
thanks!
