- Mar 29, 2010
Hi All,
I want to create a simple way to access and play my music stored on my Network drive from another room in the house.
My initial idea was to use Raspberry Pi as a cheap front end method:
Home Network -> Raspberry pi -> XBMC -> USB -> External DAC -> External Amp -> Headphones
Control XBMC via an app on my Android Nexus 7
unfortunately after some research it seems that Raspberry Pi has some USB issues and this causes drop outs and noise in the audio.
So, my next idea was to use a Windows 8 Touchscreen PC as the front end.
Home Network -> Window 8 Touchscreen PC -> USB -> External DAC -> External Amp -> Headphones
However, this method is quite expensive for what is effectively just going to be just a dumb terminal - a simple way to browse my music on my network drive and pipe it down into the external DAC.
Does anyone have any simple and more importantly cheaper ideas as to how to achieve this?
I would rather spend my money on high end DAC\AMP than the "dumb terminal"
I'd rather not clutter up my living room with a large noisy PC,monitor, keyboard, mouse etc...if I can help it, and keep it simple for my wife to use too.
Thanks for any advice\ideas
