Bolardito
- May 8, 2007
I'm planning on getting my first amp. I curreently use a Crerative Zen Vision M with Shure E500 IEM's. I will probably get the Tomahawk or maybe I'll get a Minibox E which is considerably cheaper. Which one do you recommend according to what I'm using? Is the Minibox E good enough?
Also Which cables should I buy? I have the line out dock that comes with the Zen Vision. Should I buy a mini to mini cable to use with this dock or do I need to buy an LOD cable that goes straight from the Zen to the Amp, and if so, which cable would you recommend? I checked the Qables website and they have customized Zen Vison Cables. Are this good?
Sorry for so many questions but I'm kind of confused. I really appreciate your help!
