Montoya
- Jan 13, 2010
Hi, I've been lurking here for a couple of days and I think it's time to post.
I need some headphones for gaming and music.
My requirements and priorities:
-Usage will be 20% home music (from onboard soundcard)/20% portable music(from iPod)/60% gaming.
-I'm a fan of 80s heavy metal (primary genre), classic rock, and bluegrass.
-I play mostly FPSs and RPGs.
-Priorities in order: Sound quality, positioning/sound stage, comfort, portability, looks.
-Preference for closed, though open are completely acceptable if the difference in quality or sound stage is significant.
-As far as coloring and signature goes, I'm sure I'd be happy with anything (though I don't like overwhelming bass), considering I've never heard anyhting better than Bose QC15.
-I'd like something that sounds good unamped, or doesn't require anything more expensive than the FiiO E5. I'd rather not frustrate myself with a CMoy.
I've had the ATH-A(D)700 recommended to me by other forums because of their supposed gaming prowess, but they tend to get a ton of hate around here, so I'm hesitant about them. I've also been told to buy the Shure SRH840 and ATH M50. Of course, if you believe that some other cans would serve me better, feel free to suggest them.
Thanks again for any help.
EDIT: I forgot to mention, I can't stand supraural cans. THis rules out Grados and Alessandros.
