Help me choose a portable amp
Jun 3, 2008 at 7:44 PM Thread Starter Post #1 of 4
Pantocrator
I am looking to buy a portable amp, and I am looking most at the Corda 2move, then mini 3 and a little at the headamp pico. I think the corda 2move is the best value of the ones I am looking at.
The setup is iphone or ipod touch line out to an amp to a set of headphones.
What does anybody think? Is the corda 2move a good choice? Or is one of the other amps a better fit? I would like the best audio possible at a reasonable price...
Jun 3, 2008 at 9:02 PM Post #2 of 4
What do I need to add to garner a response? I would like the amp to be nicely portable but powerful enough to handle something like HD600's. Apparently I should look at the predator as well... any thoughts?
Jun 3, 2008 at 9:08 PM Post #3 of 4
Depends on your phones as well. If your using an Ipod/Iphone, you don't need a DAC. Have you considered an RSA Tomahawk. It's $295 and stellar. I got to hear one a few weeks ago and will be purchasing one in thenear future. Plust Ray is as good as it gets in this business.
Jun 3, 2008 at 9:10 PM Post #4 of 4
I'll look it up, thanks.
