Etherate
- Jan 3, 2011
I'm after a new mp3 player because im not happy with what i have now.
What i am currently using is:
1st Gen iPod Nano with the stock apple earphones (It sounds tinny, not very clear and sharp, no depth)
I am after something that will sound as good as my Samsung Galaxy does or better. I would use my phone except for the fact that it drains the battery and isnt very comfortable to take jogging.
I have come down to either of these two options:
8GB iPod Nano (5th Gen) + $100 earphones* + Playing Apple Lossless files.
or
8GB Cowon iAudio 9 + $50 earphones* + playing FLAC files.
*The reason i cant spend more on headphones if i get the iPod is because my mate is offering his almost brand new unused ipod at a cheap price. Both options would cost me around $200 all up, cannot exceed this budget.
So what is going to give me the best sound quality out of these options?
Are better headphones > better player?
Is there audible difference between ALAC vs FLAC?
What i like about the ipod option is that i think better headphones might make more of a difference, and i like the that ipod's are more universal and will plug n play in almost everything.
