RAFA
- Jan 31, 2009
Hi
First I want to introduce, what I want to build: I would like to replace the stock cable, because it has a 1/4" plug and it is too long for portable use. Another thing is, that someone told me that i can just put on a 3.5 mm plug on it, but I do not want to destroy the stock cable. Also for me it is fun to DIY
There is only one requirement, namely I have read that some cables can worsen the SQ, for me it is just important to make sure the SQ stays like it is. I do not need any improvement and I want to keep the costs down. All the pro DIYers know how much money you can give out for a cable
What I need to know is:
- Where can I get a 3,5 mm plug with the screwthingy on (usually I do not speak english, so i do not know the right term)
- I need a nice cable, that does not worsen the sq
- And, a little bit off topic but, is there a bag or box that is smaller then the Ultrasone one?
Thank you in advance
