yavormoskov
- Aug 30, 2013
I bought Supra anniversary edition silver plated cord. It has three wires yellow/green, blue and brown (and a drain wire). The plug is the standard 3-prong US power plug. Inside the plug I see screws with different colors. If I turn the plug so the parallel flat two pins are on top the left one got white screw, the right screw is golden and the screw corresponding with the long round pin is black. Also someone told me I need to twist the drain wire together with the earth whatever this means. Can you help me to figure it out. Thanks.
