[help] Locating stores and equipment
Feb 26, 2005 at 11:46 AM Thread Starter Post #1 of 6
dewy
Hi, I have decided i'd like to have a go at some DIY jobs but I live in Australia and am finding it hard tolocate equipment need for cables, I was to make a mini-mini for my headphone amp (see below) and a rca-mini (They always seem to come in handy. Also, I am new to the diy scene, and even newer to the audio scene, What I am after is a rather cheap but descent beginners amp to make but I don't know where to start, can you buy premade pcbs? or can you use the Pegboard like pcb you can get at DSE/Jaycar that has the strips (if so how do you use them). I have minimal soldering/general electronics skills. Not sure if any aussies are members here but it is worth a try
Feb 26, 2005 at 11:54 AM Post #2 of 6
for connectors and cable. go to your local music/pa store and you'll be able to find all you want
pcb's i order from the states, but DSE does have the perfboard to build the cmoy.
parts, hardware, consumables, etc: altronics, jaycar, RS, farnell.
between those four, there isn't a huge deal that you can't get your hands on. its moreso the boutique stuff thats a bit harder to track down. i love RS and altronics though, my two main sources
Feb 26, 2005 at 12:17 PM Post #3 of 6
Thanks
Feb 27, 2005 at 2:24 AM Post #5 of 6
Skyscraper: do altronics, RS, farnell have a great deal of the required compnents? The only store you listed I am familiar with is Jaycar.
Are the cmoys descent bigginers amps? I have a sheet of perfboard here, can you post a link to a tutorial on making one?
awpagen: thanks, I will check them out too
also, the boards you get from the us, can you list some vendors orders by most reliable etc?
Feb 27, 2005 at 5:26 AM Post #6 of 6
wes are great but a pita to deal with. you have to order the catalog then call them up when you find something you want from them and talk on the phone. then schedule a bank depiosit, etc etc. about the only thing i use wes for is semi conductors, they have a massive range.
for connectors, cable, other parts, i look elsewhere and theyre usually cheaper.
www.altronics.com.au www.rsaustralia.com au.farnell.com
for a cmoy, you can get everything at either of the three and jaycar. RS and farnell have a simply astounding range of components, they do a much better job when you are looking for higher quality/performance stuff.
www.tangentsoft.net has the link to building a cmoy on the DSE perfboard, and headwize.com has the general cmoy info in its library.
