EddieE
- Sep 25, 2009
Hi,
Anyone ever come across these before? Not having any experience with speaker stuff I'm completely baffled:
They grace the ends of the speaker connectors (for clarity - the cables for connecting the adapter to the amp via speaker outputs) for the beyer ET1000/N1000 I just got.
I guess just ripping them off is the solution to actually seeing the the things work. As you can see the wire is crazy thick as well... I hope it's going to fit a normal amp or I might have to start from scratch.
So... Anyone know what they are? I'm curious.
