Oh snap! Your SR225s that were modded to look like HP1000s? I really do hope that they will work eventually man.
Help I drop my headphone in the water!! Thank you all! It is fine now.
- Thread starter hakjk
Bonthouse
- Nov 7, 2007
Hmm, how about an hour in the oven at 50 degrees celsius? I don't think that "heat" (can't really call it that hot, right?) will affect the drivers.
krmathis
Head-Fi's Most Prolific Poster
- Jan 13, 2004
Let them dry properly. Which may take several days unless you open them up and put in a warm place.
Hopefully they work again. If not, then I guess its time to cure the upgraditis.
kuroguy
- Sep 1, 2008
You're one step ahead of the Bose guys. Bose headphones melt when they get wet.
Open them up, sit them near a return grille for your air conditioners fan coil unit or on top of your refrigerator near the back. The heat from the refrigerator condenser on the back of the refrigerator is just warm enough to dry out pretty much anything in about a day.
hakjk
- Mar 3, 2008
Thank you everyone..
It is fine now...
It is fine now...
TimmyMac
- May 11, 2006
Ha, 'cure'...
Originally Posted by krmathis /img/forum/go_quote.gif If not, then I guess its time to cure the upgraditis. ![]() |
Ha, 'cure'...
chosborne
- May 14, 2009
Once washed and dryed, completely, an iPod Nano. I let it sit in a window for 2 weeks and it fired right up. Still use it to this day. Guarantee if I had tried starting it up any sooner and it would've cooked itself.
tenzip
- Aug 2, 2006
Putting the cups/drivers and cable (minus the headband) into a bag of rice could have helped. The rice acts as a desiccant and draws the water out. Or of course you can always use desiccant, if you have access to decent amounts of it, but rice is pretty commonly available. I used this method on a couple of small electronic devices that got a dunking, with good results.
Sort of on topic: My friend used to have a job repairing pagers, and he kept latex exam gloves handy for the beepers that were labeled with the note, "Got Wet". He said he estimated most of those had been dropped in a toilet, thus the gloves for the repair work.
pcyl
- Dec 25, 2007
soak it in silica gel for a week should do the trick
DaKi][er
- Jul 28, 2003
The conductivity of the water is of no concern, water isn't a very good conductor (pure water isn't at all) and there is nothing to short out in headphones, they are just a coil of insulated wire and a magnet.
What is a problem is the corrosiveness of the water, it'll eat away at the exposed parts and make a good mess of it, especially around the driver and voice coil, I woudn't worry at all about the cable or plug end
krmathis
- Jan 13, 2004
Trying to do so, or at least put it on halt for a while...
sandstorm163
- Oct 13, 2013
You can always put them in rice my friend dropped her phone in the pool and she put them in rice for a couple of days it worked
nascofair
- Jul 19, 2014
Last Month my skullcandy fell in water, and i use that mistakenly. i thought its over.. !!! but as per my friend's request i removed the earbuds and placed close to my Aircondition over that night. god grace it was ok in the morning. Thank you for making such quality headphones skullcandy .
Anna Kutrzeba
- Sep 20, 2016
i dropped my sennheiser earphones in the sink 2 days ago, theyre still drying on top of my boiler where its hot. i put them in a mug of rice too
