HELP HEADPHONE GUIDE UNDER 250$
Nov 7, 2013 at 12:57 PM Thread Starter Post #1 of 3
Strif3
   Hello im kinda new in the headphone world and i need some profesional advice on what headphone to buy my budget is 250 $(or 200 euros im from europe) and i dont know what headphones to buy i want portable headphones but with same audio quality as the full sized ones,i want the headphone to be well balanced clear bass hights and mids and the bass too be a liitle more of a skulllcrusher.
So what do you recomend,i like 2 headphones the ATH ES-7 and the SENNHISER MOMENTUM ON EAR,but from what i read about them the ATH ones are much better and they fit my demands,so what do you think?
  And if you can you can recomed so IEM that fit in the budget but tell me if its worth buying IEM over OVER EAR HEADPHONES!
Thank You!
Nov 7, 2013 at 6:49 PM Post #2 of 3
Hi!
You can also consider Beyerdynamic DT1350.
Best Luck!
Nov 7, 2013 at 8:29 PM Post #3 of 3
The ATH WS99 is my top recommendation.  I haven't heard better than this in any headphones.  They are also one of the very few headphones that have extremely good bass, while having great mids (the highs are recessed like very many closed headphones').
