gohanssjn
- Jan 28, 2005
So I own a pair of Sennheiser HD 598 that I use mostly at home, and a pair of Shure SRH 840 that I use at home but also tote to work every day.
The HD598 are open so I cannot take them to work. However, they sound great and are super comfortable.
The SRH 840 are closed and also sound great, however they just barely fit in my bag and cause quite a bit of pain on my ears after 8+ hours of listening (even with little breaks). They also don't have any sound leak, which is good because people sit to either side of me.
I see that the HD 380 Pro are now $100. Would they give me the best of both worlds here? Would I have comparable sound, comfort, and lack of noise leak from them, while also taking a bit less depth in my bag? I use a messenger bag so length and width are not an issue, it's just the depth; I see that the case packs the HD 380 Pro in such a way that the cans rotate around so they take less space.
What do you all think? Oh, and if it helps, it will be driven by a Fiio E17.
Thanks!
Thanks!
